So I tested the pickup and it does not even register on the ohm meter and the new pickup does. I took the distributor apart and am able to replace the pickup but I have one question. once apart the T shaped part that holds the reluctor and has the slots for the weights in the bottom doesn't seem right. Shouldn't it be a solid piece? the top pipe piece rotates inside the flat lower part with the slots. I did not have a lot of play in the rotor before I took this apart and I didn't have to pry very hard to take it apart after I removed the small clip inside. I do not see how this will work with this movement, t would let the rotor move around wouldn't it? Is this normal?
