Did you tighten the cold lash .006 to .008 for head growth.
If you try to do it hot you must warm before each set of rockers as aluminum cools fast.
idle sounds good to me??
wow you mean +.006/8 or at .006/8? I set the lash at .012/.012 cold. Cam card specs are .016/.018
Yea the lash will grow as it warms up some say .006 some say .008 my Indy's it's .010 but your lash should be fine check it as things move around first run in and watch for lock nuts not tight enough allowing
the lash to open up.
