but when I turn to start I loose all power to both ??
w key held to start see if you have fire at the "ign2" wire in the plastic pull apart connector dangling below the st column (a test light w needle probe tip and alligator clip on the other end to ground it works well 4 this). Dont seperate it but use the needle probe. No power "out", need to pull the steering wheel to access the sw. If power, go up to & seperate the bulkhead and check the 2 brass connectors on either side for that circuit. www.mymopar.com has the colors 4 you
