Check your grounds. Also make sure your field connections are tight on your alternator. Make sure the bulkhead wiring doesn't have any shorts or corrosion.
I did find that the wire going to stud on alt.(not sure which wire only one with stud ) the stud sheered off so I just took inside nut off & bolted terminal back on ?? I would not think that was it but????? My problem is no power in start mode to coil.key on good go to start loose power?
