Re: how do i restore this?
[Re: 62maxwgn]
#976207
04/20/11 12:31 PM
04/20/11 12:31 PM
Posts: 4,179 California
mickm
California
Personally I wouldn't bother.It's a common part that in most cases doesn't look like yours unless it had sat with the wheel off for quite some time.Most I have taken apart looked near new.The bolt is black phosphate,again common.Both pieces are under the wheel,never seen.Even if it were a concourse restoration,I don't think anyone removes a steering wheel.I'm sure there are quite a few board members that have one laying around that is in acceptable condition if you ask.If you're set on restoring it,glass bead it and go over it with some #.0000 steel wool and clear coat it.As for the bolt,run it on a "fine" wire wheel,it will look new.
it's not so much that i want it to look concours, or anything like that, i just don't think there is any point to putting a rusty part like that back together without a few minutes of work to clean it up.
i don't need to spend hours on it, just get it cleaned up and rid of the rust. i have to go find the evaporust, (which wouldn't be bad to have around anyway), but will try this also.
thanks everyone! ![](/ubbthreads/images/graemlins/thumbs.gif)
