How about just use the 383 with a good balance job
Put these pistons in it:
http://www.summitracing.com/parts/SLP-WL2315F30/
Fresh 906s with good valves and springs (little extra coin from them):
http://www.aeroheadracing.com/id6.html
Hughes whiplash cam:
http://www.hughesengines.com/Index/produ...mp;partid=25115
And this with just 100HP jets:
http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=192
Should make 450hp
I know I love the sound of this cam at idle and it is supposed to be ground to cater to low compression.
Ill let you know how this works because it is the EXACT combo that I am going to run unless PROBE makes there new pistons with the 5/64 rings and two valve reliefs (supposed to be ligther) for a 4.280 bore and 3.375 stroke with stock rod length
He can get the same lackluster heads for less at a local shop with just a rebuild of cores he has, plus I wouldn't use 906's because of the open chamber design.
If you are starting from scratch as it sounds you are find some 915
heads .
Lackluster lol, maybe to a guy that already has or has had several 450hp plus motors but to most guys the results will be far from lackluster. There is always a better way to build a motor or a cheaper way or this, that etc.
My post was more or less meant to throw an idea out there. Not the ultimate B block 450hp build. Mine was more budget minded.
Aerohead will build 915s for 100 AND they will install better exhaust valves (for the nitrous) like some manley extremes for a tad bit more money too.
I put some 906 heads on my buddies car and they looked nice and performed very well for an as cast 906. Sure they didnt make 450hp but they ran well and the motor sounded good.
Next best thing would be 440source heads (budget minded) but they dont come with nice manley or ferrea valves. They come with ok valves. I also dont like the way the seats are machined. I know I have a set and had them fixed. Ended up being into them almost 2,000 dollars.
I was just throwing it out there (using a little nitrous)......... and to be honest with the nitrous it wont really matter what heads and compression he has when the button is pushed
Dan
Oh and nitrous does count! LOL how do you think the chevys keep up!!
hahaa just kiddin.
Dan you have obviously not seen the posts about aeroheads and their quality or lack there of , that is why I say lackluster , there is nothing special about what they do , just a standard valve job , and it's been said to not be very good . with that in mind , and core charges AND shipping half way across the country you can do better LOCAL .
906's with the open chamber are a BAD choice, I use them because I HAVE TO, not because I want to, so I have a lot more money tied up in cylinder heads than I really should.
I've got 3 pairs of 906's, one set pure stock legal ... $1200, one set with very mild port work that had been worked on twice because the first shop made them flow worse ... $1600, then a set that are a stage 2ish port job, that started off as a backyard template job that wasn't very good, $1500 ... If I had to sell them I'd be lucky to get 50 cents on the dollar for what I spent.
I have a set of 915's that will end up on the stock 383 once I get the pure stock bug out of my system.
No, I haven't seen the post about Aerohead...wow. The one set of 906s my buddy bought from them seemed to work great.
Thanks for the heads up, Ill check into it.
Thought that maybe this one time the rule, you get what you pay for, could be broken.
If thats the case, I guess 440 source heads are gonna look better and better to him.
Dan
67 charger
