And on the gasket of course...
First, get the proper choke thermostat if the one in the picture above is what you have, it's incorrect. Maybe I'm missing something, but how's the motor spec'd out? Cam? heads? power brakes hooked up? Possible vacuum leaks other than the baseplates? Typically on 440's with pretty much stock cams and no vacuum leaks, they should purr like a kitten all day long, yet put you in the back of your seat when you open them wide open.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
