Thanks guys, The cam and lifters i carried over from the previous engine....i am running one ground strap from the engine to the K member,Do i run from engine to body as well?....problem now is i do not have spark from the coil wire....power to +side is there although seemingly weak...a way to test coil? my electric knowledge clearly is lacking,so any and everything will be absorbed...but first i need some power.
