TDC,pushing pressure out on number one cylinder stroke right?
Correct, then hand turn it more CW till you are at 10BTDC then w vac can roughly located turn housing till the magnet is dead even w the nearest tooth AND the rotor is under (or near under) the #1 cap terminal. If starting from scratch MAY need to reclock the inter gear a tooth and ideally want to maintain the OE plug wire routing for standardization and it lets the wires lay neatly. EDIT extra: turn the housing 360 & find the tooth that protrudes the most (least reluctor gap) then put the magnet dead even w it & if you have a vac pump (good tool to have) pump up the can slowly thru it's travel and move the housing (magnet) at the same time to keep them dead even till the clearance is the closest and set the gap at .006-8
