Carb has no choke; and the vacuum advance from the distributor is not hooked up. Only thing using vacuum is the brake booster which seemed good...should I redo the timing? Ran fine in the fall with old plugs
If the timing curve is not set right for the combo & is set at the factory timing curve, "NOT" running the vacuum advance is killer, meaning it'll bogg/fart/poo/crappy excell. ect., get the hint
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
