Seen a fluid dampener or two that were a bear to remove. All others come right off with decent puller.
Good point a fair amount of aftermarket dampers can bee too tight or too losse depending on the brand. To tight is not a bad as you cam hone it slighty to get a better fit.
All the aftermarket dampners I have purchased come with a sheet telling the end user that the dampner must be honed to size , this is why they are hard to install.
