If those are original Max Wedge heads in good shape then sell them to someone who needs them. Take the money and buy some reproduction heads or better yet, aluminum heads with closed chambers. Then you can run pump gas and the engine will work better. You should be able to get enough money from the original MW heads to finance the parts you need.
