Off-idle bogs often mean that you're running rich. You need to make sure that 1. you're idle mixture screws are adjusted properly 2. you have correct power valves, and 3. your jetting is right. The first two things can be done with a vacuum gauge and a little patience. The third requires trial-and-error and a lot more patience.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
