I called one Mopar salvage yard and they told me they had none, but thought they were being reproduced. According to BE&A and PG Classics sites, they don't have them for e body. The reason I don't want originals is because of uv damage. Mine cracked, I jb welded them and they cracked again when I tried to install. Guess I'll call around.
Check around some more for good used ones. They seem to be fairly common. But be aware that there were two different recipes for the plastic. There are the hard brittle kind which easily crack, and the flexible ones which are almost indestructable. Also, I believe there were two different screw hole configurations for the various years, so be aware of that too.... ![](/ubbthreads/images/graemlins/thumbs.gif)
I would place a "wanted" ad here on Moparts.
