Quote: I personally wouldn't take any individual's recommendation (well,maybe one or two) on choosing a cam.What works for one doesn't always work for others.Call a cam grinder,tell them what you have and what you would like,you'll be much happier in the end,that is unless you enjoy changing cams.
that be ture. You can have cams ground up for about the same cost as a shelf unit these days.
