Re: the age old question.... what cam should i buy?
[Re: rss]
#956587
03/23/11 09:58 AM
03/23/11 09:58 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Not enough dumb comments...yet
Brookeville, Md
cool lobe is over-rated it's better to have a good running engine. Buddy took your basic combo in a 68 charger, added summit 488 cam, headers, t-chain, MP electronic ing, DP4B intake (I think) stuck w/ the Cater carb and the car ran 14.10 driving like grandma. it will work with mani's. You could also look at the mopar 528 solid, although it would like a little more gear.
You would obviously know better than me since you've used this cam before, but it looks to me like the Summit 488 cam has about 62 degrees of overlap which should make that cam pretty lopey, no???
it has a little lope but nothing like the MP cams. I've run a few of them as well. My bone stock 67 GTX went from 14.20 to 13.82 with just a cam change and my mild 440 in my 67 Coronet went 12.90. When I bought the car it had a mopar 484 cam and was a dog. It didn't have enough stall or compression for the cam to work right.
