Yup, Its "10 to 73" but that's not all. The range is not linear across the sweep and the top and botton resistance can cause different results with different gauges. I have a fuel cell with the aftermarket sender (tube type) and it is nowhere near accurate. I'm on my 4th try at geting this thing re-calibrated so that the gauge reads somewhere near how much fuel is actually in the tank.
