It is more available in this area than race gas.Quote:
Availability of stations that have it.
The only thing about storing the car for long periods is the ethanol will absorb water... the water is the problem.... you could seal the vent BUT the expansion will be a problem
Condensation in the fuel tanks, metal or in fuel cells,is a big problem in airplanes that sit long peroids of times, especially in wet climates Alcohol of most types suck water out of the atomshpere, mixed with water Methannol makes acids that kills aluminum I don't know about ethanol, probally not like Methanol at all Anyone know for sure the results on ethanol and water mixed together?
