Try a Comp Cams 928, installed @ 1.875"
I ran those for a while with a .600" flat tappet cam. Fit like a glove
Same here, Eddie valves, 1.6 rockers with .600" net lift with Comp 928's, stable to 7000+ rpm. Do yourself a favor and have the valve guide clearances checked, mine were tight and I have heard MANY reports of the same.
My eddy heads had the same tight valve guide issue as well.
