Does the valve body have LBA? What type of rear band, solid or double wrap?
If you have overlap on the 1-2 shift with a LBA valve body chances are the rear band is too tight, double wrap needs to be looser than 2 turns out.
The INTERNET, the MISinformation superhighway
