Manifold: You should be able to find a port injected manifold for your engine. Even from a junkyard. FYI: The EZ system is available for port injection. It's $825 minus the injectors and the TB.
Based on 'stock' and the avatar picture I'd guess the OP is running an LA318.
The port-FI options for small-blocks are (if memory serves):
Magnum - OEM beerbarrel
Magnum - Hughes Airgap ($600)
Magnum - MP single-plane intakes (2V style and spreadbore style)
LA 340/360 heads - Eddy Super Victor
(If anybody knows of ones I've overlooked please mention it.)
So I'd say there's no easy/cheap port-FI intake option here for a street/stock LA 318.
I'd also say that a TBI configuration is quite suitable for a stock 318. Millions of TBI GM cars/trucks for evidence...
