The right engine is most certainly not a VVT
The vehicle architecture does not support vvt, and there's no easy aftermarket hack way to retrofit it easily.
It might look neat in there and you can brag to your buddies you have a new engine, but it won't even start.
The easiest way is drop the crade and pull everything out the bottom, and the times mentioned above sound about right
Rich H.
Esse Quam Videri
