Ok...Here it goes....this one's a freebie..
I have dozens of old firewall insulation "nails" kicking around, but shinny new ones will work too...
Take a drill with a bit the same size as the E Brake rod...
Drill out the open end of the firewall nail just a little, you don't have to go far...then just cut off the head of the nail....
Remove the E Brake handle, slip it in place and voila
I couldn't find a good picture of it...but you get the idea...
CHECK OUT MY NEW WEB SITE !
