well, everything went good, sounds good. good oil pressure. i'll run it a little more tommorow and then go over the valves. the trans does'nt have the converter in in, so nothing's spinning. thanks to all the helpfull info from all you guys and the shops that gave me sound advice that aided me in this build.
????? No converter? how do you start it? I thought mopar had the ring gear on the converter
it's ok to butt heads, just don't do it with a butthead
