Here's What I found: 4:12 WHEELBASE (Jan. 6, 2010) Minimum 85 inches, unless car has original engine in original location and is shorter than original, or noted in class requirements. Maximum wheelbase variation from left to right is 1 inch, unless otherwise noted in Class Requirements.
I'd call your divisional office and try to talk to a tech guy. If the car is otherwise safe, I wouldn't be too concerned.
Ron H. "Just when you think you have all of the answers...I change the questions!" "Rowdy" Roddy Piper
