It is a lowdeck motor with an airgrabber so I need at least and inch raised to get the aircleaner in the correct position
I'd have a based fabbed up then. Not sure you can "space" an entire inch out.
Sure you could , make a spacer that looks like the gasket , we have a prototrak on a bridgeport , make a drawing and crank out 3 in a heartbeat ... ok maybe 2 heartbeats ...
