Frame connectors should be stood upright in case at some later date you want to ladder bar it. Then you just holesaw holes through the connectors and insert the ladder bar crossmember through it and weld up both sides. I don't like to butt weld ladder bar crossmembers. Have you ever seen one pull loose while under braking at the top end? That is a nasty, nasty handfull!
