Dynamic are great to deal with or ATI in Baltimore. I have used both!!!
dynamic is ok .You have to make sure to tell them what you are going to make power wise and over build it from there.Spag,Alum.Drum,Good Valvebody. Ati builds a great converter,& great powerglides....However they cant build a torqueflite to save their life! I say this as I had a few from them.they say 750 horse,no problem! I make about 625 with a 493, 9 passes on the first 1 high gear went away.sent it back waited 2 months for them to rebuild it.Got it back and it was another trans.Put it in with another Brand New 8 in. Treemaster conv. 11 passes and the sprag let go.stock junk drum....you know the rest BOOM.I was on crutches for 6 months.... So I would deal with Dynamic after that...but I will say Ati's converters are good! I have a new 1 in my Turbo 400 behind my 493...
There is another guy here in Maryland that is good with 727's Ed Knolls can dig up the # if you like. Also John Richmond is good also... Just thought I would chime in to let you know on the ATI thing
could you PM me the numbers for the guys in MD?
2000 dakota
418 magnum
paxton novi 2k
T56
