Lets say I get a pair of KB flat tops, zero deck the block, and use the closed chamber (84cc) Edelbrock heads....would that be decent as far as compression and quench? With a zero deck the piston should be as far away from the head as whatever the compressed thickness is of the head gasket I'm using right? So how about this plan? Now I just need a head gasket thickness.
