Re: A-body 73up disk swap, How much does track width change
[Re: radar]
#925658
03/07/11 06:54 PM
03/07/11 06:54 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
In 73 the rear track was narrowed. That might be part of what you're seeing. I put '73+ style bbp discs on my 73 swinger and 225 tires tucked in fine on stock AR toque thrust IIs. Good luck
You won't see what the owners of small bolt pattern 72 down A bodies will because your car was designed to have that track width.
What vehicle came stock with AR torque thrust II's ???
My '73 swinger came with small bolt pattern 7.25" rear and 10" drum brakes on all four corners. The front wheels came with small bolt pattern too. When I got the car it had dodge stock 14" steel wheels with hubcaps. The rear track was noticeably narrower than the front. This is on a 1973 Dodge Dart Swinger with 198cid /6 motor and 904 transmission.
I swapped the stock UCAs and spindles for '73 up a-body style single piston brakes. At the same time I installed a hot rodded 225 engine and a ford 7.5" rear with a custom driveshaft to get big bolt pattern and installed American Racing Torque Thrust II wheels- 17"x7" with STOCK AR backspace, not custom backspace.
That's what I meant by stock.
The 225 tires tuck in fine front and back.
![](http://i50.photobucket.com/albums/f324/PhiladelphiaR/swinger/media1.jpg)
Where did you read that in 1973 the rear track was narrowed ?
Entire Thread
MileHighDart
02/10/11 07:55 PM
JohnRR
02/10/11 07:56 PM
Neil
02/10/11 09:02 PM
DoctorDiff
02/10/11 09:08 PM
JohnRR
02/10/11 09:10 PM
Fab64
03/07/11 05:58 AM
RobX4406
03/07/11 06:05 AM
radar
03/07/11 02:14 PM
JohnRR
03/07/11 03:05 PM
Jim_Lusk
03/07/11 05:49 PM
Jim_Lusk
03/07/11 05:51 PM
Jim_Lusk
03/07/11 05:53 PM
Neil
03/08/11 02:53 AM
Dartslantsix
03/08/11 03:40 AM
Jim_Lusk
03/08/11 05:15 AM
Dartslantsix
03/08/11 06:37 AM
Jim_Lusk
03/08/11 07:36 AM
Dartslantsix
03/09/11 01:18 AM
Jim_Lusk
03/08/11 05:16 AM
radar
03/07/11 10:24 PM
JohnRR
03/07/11 10:54 PM
Fab64
03/08/11 02:32 AM
Mopar_Country
03/09/11 01:42 AM
radar
03/08/11 03:52 AM
John_Kunkel
03/10/11 08:45 PM
G-Money1320
03/11/11 12:38 AM
Rick_Ehrenberg
03/10/11 05:46 AM
JohnRR
03/10/11 05:51 AM
OzHemi
03/10/11 05:58 AM
JohnRR
03/10/11 06:09 AM
OzHemi
03/10/11 06:12 AM
70HemiGTX
03/11/11 12:20 PM
