Maybe a big pipe wrench.The socket will make it so much easier.
A pipe wrench or a large crescent WILL do it & do it nicely/correctly but it's harder as the BJ flats are not very tall. The correct socket is faster in most cases but is NOT needed. I would highly suggest removing/installing the BJ w the UCA installed in the vehicle b 4 you dissassemble everything & if it's froze judiciously use the hot wrench. R&R ing the BJ w the UCA in a vise can bend the UCA (if it's real tight) & you wont know untiel you go to tap it into the cam bolt slots then you gotta compress it just the right amt to correct it DAMHIK
