Well , if you got a comp cam with the part# ending in -9 & it is'nt a billet core then you've been screwed over. .......maybe call comp cams & tell them the issue you had........Goldmember , did'nt you post something on speed talk regards this issue?
Nope. It's not an issue to me,just trying to pass along info that may help someone down the line. If someone other than Stanton needs this info just PM me with a phone # and I'll go over it again. Many comp cams ending in -9 that are cast cores(NOT ALL),catalog is incorrect,not a big deal for the application. Just don't like to hear the garbage being spewn as fact,although it's not uncommon. Can you tell which is the -9?
