Air conditioned... more specifically an RV2... was to be posible ?
I know 440s auto got them. Manuals, not I guess because the High revs or something like that. Six pack not no matter auto or manual same as Hemis, but I think due the poor room.
whats would make not to fit an RV2 on an HEMI auto beside the room.
Your speaking of an original chrysler unit ? The hemi's heads with valve covers and intake set I believe higher in the engine compartment so room is the issue. I looked at that option when I was building my clone hemi cuda convertible because I wanted air on the engine, the best compact option that fit was the sanden compressor. I did alot of cosmetics to the compressor to make it look like it belonged even though we know hemi's didn't come with air. I removed all external mounting lugs except the ones I used to mount the unit, then smoothed the case and glass beaded. Sprayed the case semi-gloss black and used blackened hardware to install it, I thought the end results looked great.
logan426
