You guys DO realize that the MAGNUM 5.2 and 5.9 engines came with 1.6 ratio rocker arms, right? Factory stock and cheap.
Yes, I'm quite aware of that. Let me try this again. The whole point of the post was to see if I could use SBC rockers on my Magnum heads. I want to use an adjustable rocker arm. I was concerned about the idle quality when using THE STOCK 1.6 rockers and the cam I'm running. That's why I asked about the use of 1.5s. You can read all of this in the previous posts above
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
