Quote: I would like to hear an engineer tell us just how many lbs of air pressure holds a tire to the bead
I am not but I'm sure it will amaze you
Sorry but I have seen tires come off the rims when the car was sideways ... your not going to see that occur on mine ... as to what pressure it takes... it s a matter of which has the greater pressure... is it the air pressure inside it or the side loading of the tire going sideways.
You better start screwing those front tires too
then
LAST COMMENT FOR ME ON THIS TOPIC
STAY SAFE FELLAS
Yeah I figured you'd quit now... since the fronts run about 45# pressure VS my 6.5 to no more than 7# with 14" across and thats not even figuring the total surface area thats on the ground so you better figure out which has the greater load .... but your right this IS my last word on this tread
