Looks like you have everything you need! Just make sure you fab a bracket for the turbo to mount to. This should be mounted to the engine. Don't hang the turbo from the headers. This will reduce the possibility of the headers cracking.
Would there be any problems having the mount come off the frame if I have solid motor mounts? Its not a motor plate.
2000 dakota 418 magnum paxton novi 2k T56
