I have not heard good things about those wires. Even if you don't think they are a problem I would check them for ohms resistence...you may be suprised. 150 ohms per foot is the MOST I would let slide. Firecore50's are yep 50 ohms per foot and worth the coin if you find your current wires suck.
69 Charger RT
