It's all back together ,machined flat,cleaned both surfaces with brake clean,coated the manifold with copper spray. And the ace-in-the-hole, I added 2 5/16"X24 studs between the center ports on the top and bottom of the flange.(does best Homer Simpson "There,take that.")
