IF it is TRULY flat .. there should not be a problem. Some are saying and comparing manifolds that are 001 ...and 040 "out-of-wack".
USING a gasket that will "insulate" the manifold from the head can be a major bummer SINCE the heat from the manifold(especially the flange area) ... bleeds-off TO the head.
