Well, after all the prep on the pistons I got the coating sprayed on and baked them for an hour after initial temp was 300 in the piston. Obviously I got it too thick on the first piston and it bit me! Will have to redo it. The rest look good. After I redo the first piston I still need to burnish them with white scotchbrite.
