Thanks for the info on the gauge i will fool around with that. Rapidrobert i went from the 10 to the 100 micron as it was cavitating the pump to much and while that iniatally sent the pressure up from where it was set then i readjusted the pressure all was good until i checked the gauge after driving it.
