Been there done that 3 times. REST! If you go into a relapse, trust me, you wont like it. Take the time you need. You need to be strong to fight it off....it will pass soon enough...rest up, and good luck
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
