all good info. bring #1 to TDC pop the cap and make sure you are on. Clean all the grounds up, hit the battery w/ a charger. One thing you might try is pulling all the plugs, un hook the coil, plug the fuel line and crank it. It should spin over realllly easy. Also make sure you have spark. When that is all done send some hot-start down the carb, it should fire.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
