my little 340 ran ok
![](/ubbthreads/images/graemlins/smoke.gif)
. it was 30over with bme dome tops (11.1 comp ) and had a comp cam soild in it 282xs 520/540 j heads mild clean up work flow 240/140 at 550 and a x-cal intake with a 950 hp carb 8" turbo action verta 727 rev. mvb and 4.57 gears and 28*10.5 slicks ( had qtp street tires) and it ran a best of 7.44 with a 1.67 short time with the slicks and 7.5x with the qtp with 1.67/1.7x short times all in full body 70 duster no back seat.frame conn. and 6deg. nose down pinion angle...i feel it should have went a little faster but i sold the short block before i could work out the frontend..the car would just crack the front tire off the line but the 60' should have been better to me.. hope this help..mike
![](/ubbthreads/images/graemlins/thumbs.gif)
also this was through the muff. With 38 total timing locked out
