ok i think i see what you are saying so if i loosen that bolt i should be able to move the axle back up?
where will all the weight be shifting too?
say force instead of weight......you wont be shifting weight you'll be relieving the force (twist) in the torsion bar.
what you did was unbolt the suspension end, that had this twisting force exerted on it, wanting to come apart violently.
you need to understand the components your trying to disassemble to avoid bad things from happening.
your only born with a set number of fingers and eyeballs.
see the red torsion bar?
that is preloaded (twisted) with that little bolt you were looking for.
then the weight of the whole car bouncing down the road loads and unloads it more.
you have to fully unload the red bar using the little bolt before taking the suspension parts off, or it go BOOM!
