PasiR,How did you attach the outer part of the wheelhouse to the quarter panel?Does it use the original wheel opening flange with a fabricated outer wheelhouse wall?I have a '74 Charger with the springs moved into the frame rails and thought about using the oe attach point vs direct to the quarter.My Charger is originally FE5 red too!The finish work on your car looks incredible!Nice work. RT
