Those look like they would fit an early A as the #3 tube comes out and over, not down like most. I already grabbed the pics to put in my design folder...FYI Early-A motor mount closer to the front axle centerline so later headers always hit the centerlink and tie rods. Or later longer wheelbase A models moved the front suspension farther forward (probably more accurate)
