On a different note regarding Neon's, her's will stall on occasion when she turns her defroster on. Of course I have not been able to get it to do it when I try. It started shortly after I replaced the eng. cooling fan assy. with a new one from NAPA. Any Idea's?
Her A/C compressor clutch is either on it's way out or the compressor is close to being locked up. When the defrost is turned in, the A/C turns on, and it'll kill the engine if the comp. is locked up. Unplug the power to the comp. and fix it in spring.
