Does it vibrate with the throttle application and at a stop or only while moving? A transmission dowel is a possibility but then it will vibrate at a stop in park or neutral as well as at speed. You have verified you're running the correctly weighted(or non-weighted) torq converter/flywheel and balancer for your crankshaft?
