OK lets try this again. I posted this earlier with a little different title and the post got bogged down with the typical arguement between professional resto shops justifing their time spent. I don't want any of that here so please, unless you have the answer I seek don't start posting your opinions.
Can someone direct me to a site that has the flat rates times for refinishing either a complete car or by individual panel?
I have a couple of cars that need repaint.
#1 car has one repaint over original paint. The repaint has the DA dance and the body needs to be blocked and resprayed. This is a solid, rust free, original sheet metal car. It does not need to be painted under the hood or trunk and there is no vinyl top.
#2 car has one repaint (color change) over original paint. Again, This is a solid, rust free, original sheet metal car. It does not need to be painted under the hood or trunk and there is a vinyl top on this one. This car should probably be stripped.
These are 66-70 B bodies.
